Rear break piston
I am changing my disks, pads and hoses, and somethings is strange to me. My rear calipers are disconnected from the brake lines, and I just could not push the pistons back to fit the new pads with enough space for the rotor, even with a C-clamp. It was just impossible. So I checked the repair manual: you have to rotate the piston clockwise as you are pushing it. So did I, with a special tool a friend gave me. It worked just fine and took me about 20 seconds per caliper.
But the pads have a little tab that must fit in the cutout of the piston. Therefore, it is impossible that the piston turns when it comes out.
So can someone explain: Why did I have to turn the piston clockwise as I was pressing it into the caliper, but it will come out straight when I press the brake pedal...
An internal part rotates as it self adjusts so the piston needs to be rotates to retract it fully.
See page 4 (61).
http://www.autoshop101.com/forms/brake06.pdf
See page 14 (326).
http://www.sanjuan.edu/webpages/jaso... Brakes TB.pdf
See page 4 (61).
See page 14 (326).
See page 4 (61).
See page 14 (326).
See page 4 (61).
See page 14 (326).
Thanks!
Snakecharmer
Apr 20, 2017 02:01 PM
