Rear clunking
Old Apr 29, 2013 | 06:30 PM
Real talk's Avatar
Default Rear clunking
I've been having this problem for awhile, On low speed turns it will clunk going up to speed 60+ Totally smooth No loud bearing noise or rough sounds, Just when turning low speeds Anyone have any idea? It is lowered It has axle spacers toe arms can't figure this out
Thanks
Old Apr 29, 2013 | 06:32 PM
Moddiction's Avatar
Former Sponsor
Rear axle nut. Search axle nut TSB. You need to retorque the axle nut.
Old Apr 29, 2013 | 06:36 PM
Real talk's Avatar
I've already done this once, It went away for awhile as i tightened up a few other suspension parts but came back shortly
Old Apr 29, 2013 | 06:39 PM
Moddiction's Avatar
Former Sponsor
Something must be loose then. Check your sway bar endlinks? Sure you torqued the axle nuts to the correct torque settings?
Old Apr 29, 2013 | 07:06 PM
Real talk's Avatar
Swaybar links are good Tightened up everything I've never used a torque wrench on the nuts Theres a little wedge on the nut i always just go a 1/4 turn from that
Old Apr 29, 2013 | 07:07 PM
Real talk's Avatar
I had a tiny bit of play in the right rear It was previous owners Ebay toe arms the joint was shot but replaced that now its still knocking just on right turns
Old Apr 30, 2013 | 01:10 PM
Real talk's Avatar
Bump
Old Apr 30, 2013 | 09:25 PM
Duyx817's Avatar
are you on coilovers? if so tighten the coil over
Old Apr 30, 2013 | 10:10 PM
Real talk's Avatar
I Actually found out earlier that the right rear spring had no tension on it I did Tighten it up with the tool the other side had alot more tension but the noise is still there i feel like it helped a bit but it's still clunking
Old May 1, 2013 | 10:46 AM
Real talk's Avatar
bump
solitarycheese
May 26, 2017 11:10 AM
oldskooleskimo
Jul 29, 2011 12:42 PM
PersianSTud
Sep 30, 2010 06:55 AM
xS2K PRODIGYx
Apr 26, 2008 07:40 PM
freq
Aug 26, 2004 06:12 PM
