Rear Diff noise question
Old May 9, 2007 | 09:06 AM
Ape_X's Avatar
Default Rear Diff noise question
Current mileage: 13k
Trackdays: 5+ hard ones
Daily driving: Light/Easy
around 11k miles I started to hear a hummm or Grrrrr noise from the rear diff when making sharp lowspeed turns. I figured it was time to change my diff fluid because of the hard trackdays so I did so, at about 12k, with Mobil Gear oil 75/90 I think, the one that everyone recommends. I used 7/8ths of the bottle.
The noise was immediately gone after the change, so now I'm a happy boy. However now after about 1000 miles after the change I'm starting to hear the noise again, not as loud as before, but its there for sure.
Is this a normal noise? Did I wait too long to change the fluid the first time after hearing the noise? Did I damage my diff?
Any thoughts from you experienced guys would be great!
Thanks!
Dave
Old May 9, 2007 | 10:18 AM
tekstar's Avatar
How loud is the noise? It is probably normal...
Old May 9, 2007 | 10:59 AM
SpitfireS's Avatar
Sharp low speed turns will cause diff grumble or grrrr or humm.
Normal.
The diff wants to "lock" because of the speed difference between left & right but it can't because of the grip.
Grumble
Why did you pick the Mobil SAE 75W-90?
Doesn't your manual state to use a straight SAE 90?
First choice (in your climate and in any other then the one mentioned below ) = LE-607.
Second choice (in really REALLY cold climates) - Amsoil 75W-110.
Ape_X's Avatar
Its audible... like if your passenger was humming to music. Its not loud, but you can hear it.
Old May 9, 2007 | 11:09 AM
Ape_X's Avatar
Normal.
Grumble
Thanks for the input!!
I picked the Mobil 1 75/90 because it was used it many writeups in the DIY section here in the Under the Hood forum. Xviper and many others said it was good for most, so I followed suit.
I understand what you mean about the diff... cause the inside and outside wheels are spinning at different speeds.
I guess its normal.. this is my first Rear drive car so... I'm still learning!
Old May 9, 2007 | 11:10 AM
jyeung528's Avatar
if it is normal, i'm curious as to why it went away after a diff oil change.
Old May 9, 2007 | 11:17 AM
SpitfireS's Avatar
AP2_S2K Posted on May 9 2007, 08:09 PM
I'm still learning!
Then also learn to read your manual
xviper used that oil also because of the low temps the car has to be started & used in and yes he has gotten good results with it.
Your own experience with the 75W-90 are different, aren't they?
Your diff starts making "noise" again after 1000 miles.
Learning opportunity
Get yourself a bottle of LE-607.
Old May 9, 2007 | 02:04 PM
tekstar's Avatar
Normal.
Grumble
So if I get some sort of grumble/grr/hum noise in a straight line at low speeds, my diff is about to go? This noise is only audible with the windows up and is very faint.. I won't be able to check the fluid until this weekend
Old May 10, 2007 | 12:23 AM
SpitfireS's Avatar
tekstar Posted on May 9 2007, 11:04 PM
Don't forget the diff is close to where you're sitting.
Not a lot of steel and insulation between you & the diff.
Some "faint noise" with a 2001 car is probably normal - hard to tell online.
Go to a local meeting and ask experienced owners their opinion.
Read your manual's recommendation on diff oil again.. and again... and again
Old May 10, 2007 | 12:27 AM
tekstar's Avatar
Thank you so much!
