Rear Diff noise question
Old May 10, 2007 | 10:44 AM
Ape_X's Avatar
Originally Posted by SpitfireS,May 10 2007, 12:23 AM
Read your manual's recommendation on diff oil again.. and again... and again
Thanks for all your input..
So I checked my shop book (the big blue Honda one) and it said to use any GL5 or GL6 SAE 90 gear oil. So I assume what I got was SAE 75?
Is the LE-607 availible at a typical autoparts store?
Old May 10, 2007 | 03:43 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I have put Mobil1 75W90 to the ultimate test. It's protection in this dif is incredible.
I use it on every single one of my customers.
Old May 10, 2007 | 03:46 PM
Billman250's Avatar
Top Answer: 1
In my experience, LE607 causes sticking of the torsen unit, resulting in clunking in low speed sharp turns. This is not however something to worry about. It's still a great product.
Old May 10, 2007 | 03:52 PM
jyeung528's Avatar
probably happens in colder temperatures?
i don't experience this in sunny so cal.
Old May 10, 2007 | 04:53 PM
Ape_X's Avatar
So then I assume that I'm just paranoid. Billman250, are you familiar with this humming noise? Maybe I didn't top off the fluid to the proper level, I just put in 7/8ths of the bottle and was done with it.
Old May 10, 2007 | 06:45 PM
FISH22's Avatar
my old ap1 had this noise, but after swapping out the fluid(607) at around 35k miles, it went away, and stayed away til i traded it in at 48k miles.
when i bought my 06 w/4 miles, it made the same noise. very deep growl hum at super slow speed turns. i dealed with it until i changed the diff fluid out at 5k mile to LE607. i'm now at 9700 miles, and the diff is still as quiet as the day i changed the fluid. i'm in love with LE607!
Old May 11, 2007 | 01:59 AM
SpitfireS's Avatar
AP2_S2K Posted on May 10 2007, 07:44 PM
No, you got a multiweight oil.
Honda recommends a single weight.
Why?
Probably because it uses less ink in the manual
With every mechanical device one needs to take the proper warm-up period into consideration.
If you're worried about your diff at -11F you should also worrie (a lot more IMO) about your engine at -11F and think twice about your choice in engine oil.
Old May 11, 2007 | 03:05 AM
Billman250's Avatar
Top Answer: 1
Cold had nothing to do with it. It will do it when it's 75 degrees out. Like I said, it's not a cause for concern.
polar2k
Jul 15, 2014 08:20 PM
Ek_Jak
Aug 26, 2009 01:25 AM
krnboi4370
Dec 10, 2007 01:54 PM
highwaystardoritos
Jun 2, 2006 05:42 PM
BlueS2000Boy
Jan 9, 2006 07:55 AM
