Rear Differential Leaking
Old Oct 13, 2005 | 10:16 AM
XLeezardx's Avatar
Default Rear Differential Leaking
hey guys, I just noticed a oil spot on my driveway today. Looked under and the bottom where the drain bolt is under my Diff had some oil. The bottom casing was kind of wet. Did i not tighten the drain bolt tyght enough? I do have a washer in there too. Im worried im at work right now, im bout to get off early and jack up my car.
Old Oct 13, 2005 | 10:36 AM
xviper's Avatar
Yes, there is a washer that should have been put on the bolt. Many people drop this into the drain pan and never put it back on. In fact, every drain and fill bolt on this car has a washer.
Old Oct 13, 2005 | 10:47 AM
shaolin's Avatar
good tip. i'll remember that
Old Oct 13, 2005 | 12:04 PM
SIIK2NR's Avatar
Be careful!! and don't overtighten your drain bolt and strip your diff.
Old Oct 13, 2005 | 12:42 PM
VR4's Avatar
VR4
your car saw the 350Z pulling in and pissed itself.
sorry. couldnt resist.
Old Oct 13, 2005 | 02:03 PM
elude's Avatar
what happens if you loose to much diff fluid? loss of performance?
Old Oct 13, 2005 | 02:08 PM
VR4's Avatar
VR4
blown diff.
with loss of fluid its usually a lockup and loss of control.
Tboy
Feb 3, 2014 04:59 PM
bhchase
Nov 12, 2013 08:17 AM
brock
Jan 13, 2008 03:31 PM
RGlbk
Jan 5, 2008 02:45 PM
05thumper
Jul 3, 2007 12:57 AM
