Rear-end and diff question...
Old Oct 17, 2009 | 06:19 PM
craigeoh's Avatar
Default Rear-end and diff question...
I just purchased a 2003 S2000 with 72XXX miles.
1) How would you know if you have a rear aftermarket diff? The car seems to be real aggressive when I start off and also seems to want to spin/spool the rear tires in most turns. I am new to the car so it might all be driver error. It just feels like it has more bite then my friends S2K.
2) The rear seems to have a vibration under low speed hard acceleration. I was told that it is most likely the axles due to the car previously being lowered and not having axle spacers. It is now all back to stock. If the CV's are worn, would this cause low speed vibration under hard acceleration?
Thanks..
Old Oct 18, 2009 | 07:09 AM
negcamber's Avatar
1) If you have stock gears and running stock size tires at the rear, then you should see 30mph at 4000rpm in 2nd gear.
2) Axle spacers do not prevent damage to axles on the s2k. They may have some benefit on FWD cars though...but not the s2k. The vibration is from pitting in the CV buckets. Spacers can however get rid of the vibration by moving the place where the spider gear rests inside the CV bucket...basically moving it away from the pitting. Since you may not know how long the car was lowered before, adding spacers may or may not work. Your best bet will be to swap the buckets from right to left.
Learn more here:
https://www.s2ki.com/forums/index.php?showtopic=693173
s2k aok's Avatar
http://www.turnzero.com/technical_resource...gear_calculator
oem is 4.10, the other popular gearing is 4.44, 4.56/7, and 4.77s...
Old Oct 18, 2009 | 04:20 PM
craigeoh's Avatar
Thanks will check rpm's tomorrow..
Old Oct 18, 2009 | 06:06 PM
dammitjim's Avatar
What kind of tires do you have an how is the tread?
Stock you should hit vtec (6000 rpms) at 40mph in 2nd and 60 mph in 3rd
Old Oct 18, 2009 | 07:22 PM
craigeoh's Avatar
Stock tires.. Will check rpm's tomorrow
Carl Bourbon
May 29, 2014 04:20 PM
jon3501447
Oct 29, 2013 11:54 AM
Beyond_Redline
Nov 11, 2010 02:57 PM
rob!
Dec 30, 2008 02:00 PM
Moemers
Feb 25, 2006 10:14 AM
