rear end noise
Old Nov 12, 2004 | 09:23 AM
allenheathdj's Avatar
Default rear end noise
my rear end has started to make a funy noise, when I slow down in gear in neuteral the rear makes a ticking noise, kinda like the wheel of fortune wheel...when the car slows down it gets louder. is this from my diff, axles or the drive shaft??? anyone know
Old Nov 12, 2004 | 12:00 PM
beroznikmal's Avatar
Cv join maybe.... there have been previous post on bad CV joins due to not retorqueing the spindle nut....... does the rear end vibrate?
Old Nov 12, 2004 | 02:21 PM
no vibrations and my 1/2 shafts and diff have been replaced.
Old Nov 12, 2004 | 08:11 PM
xviper's Avatar
Replaced with a complete new diff or just rebuilt? If rebuilt, it may have not been put together correctly. This can be a common cause of diff noises.
Old Nov 13, 2004 | 03:01 AM
CoralDoc's Avatar
A loose spindle nut does not cause the CV joint to go bad. The loose spindle nut noise is similar to the one described by allenheathdj, and is due to the splined shaft shifting in the hub.
A ticking noise when slowing or accelerating is more typically a loose spindle nut, clicking or clunking while turning, especially slowly at high steering angles, is often the CV joint.
Old Nov 13, 2004 | 08:40 AM
thanks for the correction......
Glove
Nov 23, 2015 09:35 PM
s2kbenztech
Tampa
Sep 22, 2009 01:54 PM
RangOs2000
Aug 15, 2009 05:12 AM
pli
Jun 13, 2008 07:27 AM
Redline Drift
May 20, 2004 06:05 PM
