Rear End Vibration under Accel
Old Aug 14, 2019 | 05:00 AM
maranelloboy05's Avatar
Default Rear End Vibration under Accel
Assuming this is going to be cv cups but thought I'd ask. Only getting this vibration at higher speeds under moderate to heavy accel. Really bad at 3rd gear and above between about 3500 and 6000 rpm, seems to clear up a lot when into vtec. Is this still likely to be the axle cups? I got vibrations when I first lowered my car about 30k miles ago, added spacers and swapped the cups then but I was getting the vibration at lower speeds. Is this just a new wear area showing up?
Old Aug 14, 2019 | 05:36 AM
Jim Bravo's Avatar
I'm no expert, but it still sounds like the axle cups to me.
When mine was vibrating, I swapped the cups AND added spacers at the same time(like you) and still had some vibration during acceleration. I left the cups swapped, but pulled the spacers out and the vibration hasn't been back.
Maybe doing both at once puts the cups back at a bad spot. I'd say pull the spacers and go from there.
Old Aug 14, 2019 | 05:49 AM
engifineer's Avatar
If it is the common pitting problem then it may have pitted on the other side now if it has been launched hard a lot. When you pull the cups off you can clean out the grease and see where the pitting is occurring. Pitting on the edge that the bearing pushes against when driving the wheels forward is what you are looking for.
Old Aug 14, 2019 | 06:52 AM
Thanks, I actually just grabbed a set of used axles I found locally for a good deal. Just wanted to see if not getting the vibration 100% of the time is possible before I swap em.
Old Aug 19, 2019 | 08:27 PM
jyeung528's Avatar
let us know if this fixed the problem.
JayJones
Aug 26, 2013 04:35 PM
JayJones
Aug 26, 2013 12:55 PM
Andersonracing
Apr 13, 2013 10:11 PM
Working_Class_S
Feb 14, 2012 03:40 PM
sayaingokou311
Aug 9, 2010 04:55 PM
