Acceleration vibration.
Old Apr 12, 2013 | 05:53 AM
Andersonracing's Avatar
Default Acceleration vibration.
Ive recently come upon a vibration in the rearend after bending my RR wheel. I had the wheel straightened and that vibration went away, but a vibration still occurs when under acceleration at probably 40mph and up. Ive yet to do the new axle torque (car is a 00' with 77k miles)
possiblilties:
Axle torque?
Bent axle face?
rear end mounts?
rear gear? <--hope not.
Old Apr 12, 2013 | 06:25 AM
DAT-52K's Avatar
possiblilties:
Axle torque?
Bent axle face?
rear end mounts?
Bent rear drive shafts. Got mine replaced, No more vibration @ revs. Get a Drive shaft spacer too before you damage your new ones, Usually happens because of shitty suspension and your S is too low without the spacers.
Old Apr 12, 2013 | 09:17 AM
Originally Posted by DAT-52K
possiblilties:
Axle torque?
Bent axle face?
rear end mounts?
It might be, when i bought the car it came with Ksport coilovers and it was way to low so i raised it a good 2". I took a dial indicator to the drive shaft ends and was only seeing about .005" runout.
Is there a spec?
Old Apr 12, 2013 | 11:36 AM
apme123's Avatar
axle buckets, swap left to right
Old Apr 12, 2013 | 11:43 AM
Ill pull one side apart tonight and see how the wear is, if its the case i can get new axles/buckets for 100$ a piece
thanks for the input!
Old Apr 13, 2013 | 10:11 PM
took apart the axles today, the Right axle showed some darkening in the axle bucket nothing to severe. On the other hand the LR had two pretty significant wear spots. I swapped the buckets and re greased the boots and its working perfectly again =) thanks S2ki!
ragtophardtop
Jul 1, 2018 10:53 AM
aziego
Sep 28, 2017 02:49 PM
JayJones
Aug 26, 2013 12:55 PM
JDMQuip
San Diego S2000 Owners
24
Jan 27, 2010 02:50 AM
Boost76
Jul 17, 2009 10:29 AM
