rear shakes when accelerating passed 60-help anyon
hi i hope someone can help me with this issue, i changed my shocks and springs today and now my rear shakes when i accelerate passed 60. i've checked the springs to make sure they they are sitting properly and that the wheels are screwed on tightly twice. does anyone know wat else could be causing this shake that didnt seem to happen before i lowered the car?
Originally Posted by 99sss2k,Nov 10 2007, 08:51 PM
I changed my shocks and springs today
https://www.s2ki.com/forums/index.ph...topic=39249&st
https://www.s2ki.com/forums/index.ph...topic=47357&st
https://www.s2ki.com/forums/index.ph...opic=167582&st
Originally Posted by 99sss2k,Nov 12 2007, 04:01 AM
if this is the case, would i best replace the inner CVs or modify the inner CVs?
If your car has high miles, replacing the inner cv's may take care of the problem, but I do not know for sure. We'll have to wait for someone else to chime in.
If the shaking is the CV joints, another repair option is to switch the inner joints side to side. This give you a new load-bearing surface and may eliminate the problem. Since the fix is free (except for the labor involved), it's worth a shot to see if the CV joints are indeed the problem.
