rear swaying back and forth @ high mph
Old Jan 12, 2005 | 03:49 PM
RACER's Avatar
Originally Posted by lamvu
Once again does toe in, on the rear tires cause it to wobble?
1/4" of toe in is good. Thats what it should be set at.
So i considered the ball joints? i re-tightened them and it still does it
How did you re-tighten your ball joints
could my ball joints go bad? the car only has 25k on it.
Not normally, but if you hit something, then most definitely.
Old Jan 12, 2005 | 03:56 PM
mikegarrison's Avatar
Originally Posted by lamvu,Jan 12 2005, 04:13 PM
ok i think i found the problem. I jacked the rear end up in the air and kept the tires on and then shook the tires violently. The driver side tires wobbbles up and down and side to side. So i considered the ball joints? i re-tightened them and it still does it... could my ball joints go bad? the car only has 25k on it.
Wouldn't this more likely be a wheel bearing problem?
Old Jan 12, 2005 | 03:57 PM
twohoos's Avatar
This is a sign of wheel bearing failure and/or loose axle nut. Get it serviced asap.
Old Jan 12, 2005 | 04:34 PM
RACER's Avatar
Old Jan 12, 2005 | 06:30 PM
s2kboost's Avatar
did u take off the rear strut bar
Old Jan 12, 2005 | 09:19 PM
lamvu's Avatar
i figured out what the problem was.. it was a loose axle nut... all i had to do was tightened it and it was fixed.. as for me tightening the ball joints, i meant i made sure the bolt that held the knuckle to the control arms were tight and the cotter pins were in.
And as for getting it serviced i'm pretty sure i can do it at home.. I even pressed in wheel bearings for the front @ home just using a vice and hammer. =P
Old Jan 12, 2005 | 10:32 PM
RACER's Avatar
Did you stake the nut? If it makes any creaking noises, you will have to remove the nut, apply grease to the surface area of the nut where it contacts the hub and re-torque it to 181 ft lbs. Honda has suggested torquing this nut to 220 ft lbs. It wouldn't be a bad idea to also replace both nuts with new ones.
If the cotter pins are in their respective positions, there is no need to check the torque on the castle nut as the shaft of the ball joint is tapered. Once the castle nut is tightened for any length of time, it take a special tool to separate the ball joint again.
Old Jan 12, 2005 | 11:05 PM
lamvu's Avatar
the reason was I had to replace the whole rear suspension due to an accident. Tthat was my reasoning to making sure it was tightened. Thanks for the info =P
Disgustipated
Apr 30, 2011 09:21 AM
124Spider
May 27, 2008 01:19 PM
Illiniwek
Jun 11, 2007 02:45 PM
armeN
Mar 15, 2007 02:50 PM
