Rear wheel will not move!
Originally Posted by heyne' date='Feb 1 2005, 09:31 AM
When i put the car in 1st and let off the clutch the mph starts to climb. At idle it says it is going 8 mph. When really the car is not moving at all!
Oh, and the brake can still be seized but this would be just another issue. Also, if something is broken, that seized side could be frozen from the output shaft on out to the wheel hub.
So i jacked it up and stuck my head under there. It's missing a 1/2 axle! on the same wheel that wont turn. Well i know ill have to get one before the car will move on its own. but i still can't figure out why the wheel wont spin. I went at the brakes with a rubber hammer and then a real hammer on the rubber one. but still now rotation.
Also when i put the car in gear where the axle should be was spinning. this is how i was getting speed on my gauges.
I thought the ECU used the ABS sensors to determine speed.
