Rebuilding Head
Old Mar 24, 2012 | 05:48 PM
Tech2uned's Avatar
Default Rebuilding Head
Today I had a leakdown and compression test done on my AP1. Cyl number 3 had a compression of 140 psi, while the othere had an average of about 210. We had about 80% leak on that cylinder. The exhaust valves are pitted, and burned out as well. So basically I would like to get some insight on how I should go about rebuilding the head. I have done a quite a bit of searching, but I have been lead to many dead end threads leaving me with questions still lingering in my head... My car has 90k miles, so I also want to take care of any other high mileage maintanence.
These are the things that I am considering on getting(If you have any input on these parts, do not be afraid to say anything!):
Honda Gasket set for head
ARP Head studs
Timing Chain Tensioner
Ferrea Valve Train
I have also considered Supertech for my valve train. I have read where some people have had issues with the Ferrea retainers coming in contact with the center rocker. Also, should I go dual spring? I will be staying with stock cams. Anything else you guys can think of that I should also do? Thanks a lot for your time!
Old Mar 25, 2012 | 06:40 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
In my experience arp head studs have been a complete failure on this engine.
Old Mar 25, 2012 | 07:34 AM
Tech2uned's Avatar
I did see that you posted that on another thread. I may go boosted later, but I dont mind going with stock if that is going to be my over all best choice. What is a good website to order factory parts? Thank you for your input though!
Old Mar 25, 2012 | 11:38 PM
dwight's Avatar
http://www.hondaautomotiveparts.com/
Silver_Bullet_S
Oct 6, 2018 01:15 AM
Dereks2k
Aug 6, 2013 02:06 PM
Tech2uned
Mar 13, 2012 10:55 PM
jaundice
Jul 12, 2010 02:25 PM
ERL_S2000
Mar 24, 2007 08:27 PM
