Alaniz Head
Old Jul 10, 2010 | 03:14 AM
jaundice's Avatar
Default Alaniz Head
I recently purchased Kane.s2k's Alaniz ported head. I have a built block with sleeves and 9:1 compression CP pistons. The head has 1.5 mm oversized intake valves and 1 mm oversized exhaust valves with AP1 cams.
Questions:
1. Will I have any valve clearance issues with these oversized valves and my pistons ?
2. I plan on re-tuning anyway, but any issue with driving (no boost as IC is off) to the tuner with new head and old tune?
3. What kind of power can I expect to add with this new head?
thanks for any input...
Old Jul 10, 2010 | 05:26 AM
Sideways's Avatar
Questions:
I think you may have the valve sizes incorrect. Alaniz built a few heads and never went larger than one mm on exhaust and 0.5mm on the intake as far as I am aware.
You should have adequate clearance with the CP pistons. That is the setup I am running.
You can drive a short distance but just be very easy on it before the tune.
The power should go up 10 to 15% with a good tune.
Heads up to others, Alaniz is a great head carver and a thief. Do not deal with him, he will screw you take your money and goods too. He has takes several people on this board for over $10,000 total that I am aware of.
Check with Central Florida Turbo about the heads he stole from them if you doubt me.
Finding a used Alaniz head is good, Congratulations to the OP.
Old Jul 10, 2010 | 05:50 AM
jaundice's Avatar
Thanks. Here is for sale thread with specs on the head.
https://www.s2ki.com/forums/index.php?showtopic=785081
Old Jul 10, 2010 | 06:04 AM
Sideways's Avatar
Always more increase in size on the exhaust side since that is where the gains are .
It's probably an error and should be 0.5 instead of 1.5.
If the head is off you can physically measure them to remove any doubt.
Anyway, it's a mute point.
Bottom line is congratulations on getting one and let us know what the out put is when you dyno.
Old Jul 10, 2010 | 06:13 AM
jaundice's Avatar
Thanks. I will.
Old Jul 12, 2010 | 02:25 PM
TRBOKEV's Avatar
Be sure to have the head checked for straightness before you install it.
youngkilla
Jun 8, 2014 07:43 PM
Tech2uned
Mar 25, 2012 11:38 PM
faukengenius
Nov 27, 2007 03:38 PM
ERL_S2000
Mar 24, 2007 08:27 PM
TougeBomber
Jul 5, 2005 10:21 PM
