Rebuld
FYI there is a high degree of risk of issues down the road if you do not take it to one of the recommended people/businesses in this thread. There are many strange details on rebuilding these motors that most mechanics will overlook because "I know what I'm doing, I've rebuilt 1000+ engines." We've heard many, many, many stories of that on here. A quick chat with Jordanskartell or Billman250 and they can tell you what those differences because they've built a lot of THESE EXACT motors with a proven track record. Just because your shops does "Honda/Acura only" does NOT mean they can rebuild an F20 or F22 by ANY means.
Edit: And FYI even if they "go by the manual" to make sure to do it right, there are a couple of errors in the manual that Billman250 and Jordanskartell are aware of and avoid but a dealer/Honda/Acura specialist almost certainly will NOT.
My car is still running with one-size-fits-all bearings (ACL), franken parts from 3 separate failed motors over 30k miles later and counting.
Anyone that has experience with building Porsche motors, I would trust with the S2k engine because Porsche uses a very similar type of FRM coating on the cylinders. In fact theirs requires a bit more prep work to do the honing than ours.
From what I understand, and I'm not a mechanic, ACL bearing come "with a size that fits an F22, or whatever" and a lot of people throw them in their rebuilds thinking that they will last when they dont understand that our motors CAN have different size bearings between the cylinders. 10k miles later and boom, you need a rebuild. However, you may have been lucky and had all the same size and gotten the correct ones from ACL that matched. Some (a lot) of mechanics don't realize this.
There are also well documented ERRORS in the engine rebuilding part of the F20 and F22 Haynes manuals, that have never been corrected. So if Joe Shmo goes to rebuild an F22 and wants to do it "by the book" there is still a chance it will end up poorly.
Edit: There is actually a recent thread in the under the hood section that explains a lot of this, check it out
I too would like to hear what makes the S2k motor rebuild unique that other Honda motors don't have. I understand there's error in the service manual, but those are typographical. I have not yet seen anyone mention a feature the S2k motor has that others do not.
Originally Posted by dagle' timestamp='1441509616' post='23738411
[quote name='jkelley' timestamp='1441282586' post='23735603']
I wasn't citing my rebuilds as a means to 'debunk' your 'data', it's context to my experience in regards to rebuilding these exact motors. I have 2 disassembled shortblocks right now as well waiting for rebuilds (I'm working on an EVO at the moment, and i'm a hobbyist not a mechanic)
It's not luck, I think you're simply not informed (and no one expects you to be if you're not a mechanic) as to why there are different sizes. I had a set of main, rod and thrust bearings laying around that I got with other engine parts I bought and mic'd out acceptably across all crank surfaces so they went in. It's really not that difficult.
Can you elaborate on the error? Tolerances, clearances, torque specs or wat?
[/quote]
Originally Posted by TheKhemist' timestamp='1441476935' post='23738129
Too bad to hear about the F20 short blocks being all gone. This thread is why I am going to get a new OEM F22 shortblock for my 07 S
Originally Posted by 99SH' timestamp='1441484307' post='23738196
[quote name='TheKhemist' timestamp='1441476935' post='23738129']
[/quote]
I've never heard of the AP2 cranks ever being discontinued.
Originally Posted by TheKhemist' timestamp='1441564208' post='23738777
[quote name='99SH' timestamp='1441484307' post='23738196']
[/quote]
[/quote]
http://www.hondaautomotiveparts.com/...FT&vinsrch=yes
Russ Watts
Jul 4, 2013 02:24 PM
