Recommended Torque Wrench Ranges
Old Feb 12, 2018 | 12:29 AM
rosen2k's Avatar
Lightbulb Recommended Torque Wrench Ranges
What's the consensus on recommended torque wrenches to cover basic maintenance - fluids, brakes, wheels, etc?
Sources:
Which Torque Wrench Range is Right For Your Ride MountzPro At The Track
https://www.s2ki.com/forums/showpost.php?p=21645399&postcount=17
https://www.s2ki.com/forums/s2000-un.../#post23624101
http://www.bluetoad.com/publication/?i=470827#{"issue_id":470827,"page":24}
Using CDI torque wrenches as an example, there are two configurations:
(3/8) 5-75 + (1/2) 20-150
(3/8) 5-75 + (1/2) 30-250
Opinions between these two options?
Recommendation for the lb-in wrench for the smaller torque jobs?
Last edited by rosen2k; Feb 12, 2018 at 06:08 PM. Reason: Fix incorrect torque values
Old Feb 12, 2018 | 08:55 AM
zeroptzero's Avatar
get one 3/8th's wrench that goes from 2-22 ft lbs (something like 20-250 inch lbs) for all of the smaller bolts on the car, and spark plugs etc. Then get one that covers 20-150 ft lbs for the larger bolts like suspension, lug nuts, etc. that will cover you nicely. Two wrench minimum and you shouldn't strip a bolt ever again.
Old Feb 12, 2018 | 11:51 AM
Chris_Lum's Avatar
^^i agree.
i have 2 CDI Wrenches which can pretty much do anything i need.
3/8" Drive 5-75 ft*lbs
Amazon Amazon
and 1/2" Drive 30-250 ft*lbs
Amazon Amazon
Reason i chose 250 ft*lb wrench is because billman's axle nut suggestion is to retorque the nut to 180 ft*lbs (estimated factory torque) + 60 degrees so i figured It would be good to have the higher range. Better to have it and not need it, than need it and not have it.
Old Feb 12, 2018 | 12:33 PM
Jah2000's Avatar
Originally Posted by Chris_Lum
^^i agree.
https://www.amazon.com/CDI-752MFRMH-...wrench+3%2F8+5
https://www.amazon.com/CDI-2503MFRMH...h+1%2F2+30-250
I wanted this exact combination/both of these exact ones too. But, I'm broke, lol... so I just got the 10-100 CDI wrench.
Seems to fit every need thus far (except the axle nuts of course, like you mentioned... or a crank pulley bolt, which I'll probably never touch). Majority of Honda bolts are less than <100lbft spec. If I need any crazy high torque specs, I can always just rent at Autozone.
Old Feb 12, 2018 | 02:03 PM
zeroptzero's Avatar
torque wrenches with large spans tend to be less accurate at lower settings, hence my recommendation for 2 wrenches if at all possible. Also, 3/8ths drives are more accurate for lower settings, and 1/2 inch rives more accurate at higher settings. I understand the cost argument though and if you can only afford one wrench, but it really feels like crap when you strip a bolt , it is the worst feeling in the world I say. lol. When I first starting wrenching on my cars I used a single 0-150 ft lb 1/2" drive torque wrench on smaller bolts, even though it was properly set I was stripping bolts and it really pissed me off. Since that time I always made sure to have a minimum of 2 differently sized wrenches.
N777CK T
May 12, 2014 10:07 PM
ConanO'Brien
Jul 3, 2011 11:49 AM
thrillissues
Jul 6, 2009 02:44 PM
ph09kng
Sep 18, 2008 10:47 AM
Nobody
Apr 4, 2003 04:21 AM
