redline MTL
Old Jul 16, 2001 | 10:06 AM
Y2K1S2K's Avatar
Default redline MTL
is there a difference between redline MTL and MT-90 for the tranny??? i ordered some and i got the MTL, but it seems like everyone who is using redline for their gearboxes is using the MT-90...is MTL ok?
Old Jul 16, 2001 | 11:43 AM
SCS2k's Avatar
I may be wrong about this but I believe that the MT-90 is for the differential and the MTL is for the transmission.
Old Jul 16, 2001 | 12:36 PM
UCrazyKid's Avatar
The are too different products with different additives. Find out for sure if you have the right one before using them. You don't want to mess things up with the wrong stuff. Some of those fluids contain additives that can be corrosive if used in the wrong application.
Andy
Old Jul 16, 2001 | 02:13 PM
Y2K1S2K's Avatar
um so which is for the transmission?
Old Jul 16, 2001 | 03:09 PM
joe_s2k's Avatar
I would go with the MTL
M= Manual
T= Transmission
L= Lubricant
I know, I'm a smart-a$$!
After reading the Redline Oil Website, it seems that both can be used in the tranny. Read it for more info.
Old Jul 16, 2001 | 08:33 PM
pfb's Avatar
pfb
MTL & MT-90 are both gear oils with special additives for manual transmission syncro's.
The MTL is 70W80 viscosity and the MT-90 is slightly heavier, at 75W90.
I think the recommended Honda MTL is 75W80, so neither is an exact match but I'd go with the regular MTL (70W80), not the MT-90.
By the way, I've called Redline numerous times, and they are always very happy to discuss your needs and make a recommendation.
For the diff, you probably want to use Redline 75W90 gear oil, although with stories of breaking diffs, Redline shockproof gear oil might be an alternative.
o'malley_808
Sep 23, 2008 12:54 PM
high on nine
Aug 4, 2003 03:19 AM
TypeSH
Sep 30, 2002 07:24 AM
navybeaN
Sep 18, 2002 11:46 AM
mwy23
Apr 25, 2002 09:31 AM
