reducing/eliminating wind buffer noise from top?
Old Nov 3, 2008 | 06:39 AM
hansai00's Avatar
Default reducing/eliminating wind buffer noise from top?
Everytime I go past 60 mph I get a lot of wind buffering from the soft top. When I pull down on the soft top it is eliminated. I tried using Shin-etsu grease to make it seal tighter but no luck.
Has anyone run across this issue before? It's a MY00
Old Nov 3, 2008 | 06:43 AM
vtec9's Avatar
Your strikers may be loose/worn out, or the hook(s) on the windshield frame might need re-aligning.
Old Nov 3, 2008 | 03:53 PM
4bang6's Avatar
Old Nov 3, 2008 | 04:59 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I've found new strikers and latches don't really do much to fix it.
Find a good welder to add a little metal on the latch hook where it touches the striker, it works awesome and will last forever I've done quite a few of these weld jobs myself...
Old Nov 4, 2008 | 07:05 AM
my2ks2k's Avatar
replacing the strikers completely eliminated my wind noise (from the front.)
the problem is, the hook on the latch wears a groove in the striker plate over time, and eventually the top isn't pulled as close as it should be. having someone weld a little metal onto the plate will work fine, but new strikers worked for me
Old Nov 4, 2008 | 07:22 AM
vtec9's Avatar
An easier alternative to welding is buying some rubber tube (like air tube for fish tanks) and using it as a sheath for the hooks.
Old Nov 4, 2008 | 08:06 AM
EVAN&MONICA's Avatar
Buy a hardtop
SlowRunner
Aug 18, 2008 05:24 PM
Kiteland
Jul 16, 2005 03:26 AM
DallasClassic
Jun 9, 2005 08:52 AM
JEVON
Feb 24, 2005 12:17 PM
