REMOVAL OF CAT. CONVERTER
Old May 4, 2005 | 12:57 PM
JROSEN's Avatar
Default REMOVAL OF CAT. CONVERTER
Does removing cat. converter and replacing with a test pipe really add any power and/or improve driveability?
Old May 4, 2005 | 01:32 PM
S2oooNvegas's Avatar
dude, the top end power, is just sick sick sick. love it.
Old May 4, 2005 | 01:35 PM
73Zero's Avatar
Installed a Spoon test pipe, and never looked back...
Old May 4, 2005 | 03:27 PM
Bane's Avatar
Where are the flamers (lol) that are gonna bitch about killing the environment? I thought they would have found this thread by now
Old May 4, 2005 | 07:57 PM
BigSkinnyS2k's Avatar
you guys got any kind of 02 sim or you just ridding with the CEL on ?
Old May 4, 2005 | 08:04 PM
Hamiy's Avatar
Yep, i'm running a testpipe. Even in Cali- cops can't touch this....
hehe
I used the technique of the 2 18mm spark plug anti-foulers. Works great so far, and an easy install. You can search for the page
Old May 4, 2005 | 09:25 PM
speed4tu's Avatar
I also have a test pipe, wouldn't go back to the cat for anything.
Bane, I'm with you on the environment lovers thing, I figured they would have chimed in by now.
Old May 4, 2005 | 10:30 PM
tizbad2k's Avatar
I think that even if there were enviormentalists ready to chime in, they would be of the kind that have Stooks, and an owner of a Stook probably cares more about the driving than anything else.
Also I bet that without the cat (do we have 2?) the S would still prolly make only a bit more pollution than some of the other vehicles out there.
Oh and as far as O2 simulators , what exactly would you need? All an O2 sensor does is give a voltage output corresponding to the sensor input. I guess you might be able to just hookup some sort of voltage source to it???? But thats only if it would be considered ok by the ECU to see a constant value from the O2 sensor, the case might be that it needs or expects to see certain variations , like at WOT or maybe while warming up, but i dunno.
Old May 4, 2005 | 10:36 PM
Bo_Vien's Avatar
Have any of you with test pipes driven by those emissions testing sensors? I don't know what they're called exactly, but here in Dallas, they have these setups situated at the onramps to the freeways. There's a big sign that says "emissions testing" and a camera to record license plates I suppose. These setups are random as they're moved all over the metroplex from what I can tell.
And to answer JROSEN's question, I had a test pipe on my RSX, and there was definitely a noticeable difference once VTEC hit.
Old May 5, 2005 | 12:05 AM
C6400hp's Avatar
[QUOTE=Bo_Vien,May 5 2005, 12:36 AM] Have any of you with test pipes driven by those emissions testing sensors?
