Removal of PCV valve, when using Krank Vents?
Old Jun 16, 2007 | 02:52 PM
Boostaholic's Avatar
Default Removal of PCV valve, when using Krank Vents?
Im "optimizing" my vacuum system, and from what I know about the pcv valve, it is just a one way valve, just like the krank vent. Except of course the KV is stronger than the pcv. If I have the krank vent, I don't need the PCV do I? It seems like a bottleneck, or redudant to me. Can't I remove the pcv and just plug a hose in the whole instead, using my current catch can/Krank Vent system? Just wanted to doublt check before I do this, thanks.
Old Jun 16, 2007 | 03:32 PM
FISH22's Avatar
when i had these on my 03, i had the oem pcv valve still installed. i can understand how your calling it a 'bottleneck', makes a lot of sense. i dont see though, a reason to remove it. i had great results(N/A) with the all working together....stop burning oil, and the car felt great.
Old Jun 16, 2007 | 04:04 PM
stphotographer's Avatar
Not necessary to remove it. Some people have drilled it hollow. Its also been reported that this may cause idling issues.
I'd keep it in just to be safe.
Old Jun 16, 2007 | 05:13 PM
s98d7fs's Avatar
Drill out the PCV valve so that you can still use the elbow to plug into the valve cover.
The idling issues that stphotographer mentioned are a result of the vacuum in the crankcase being released a bit by the spark plug tube seals. That issue can happen with the PCV valve, and is actually more annoying than with the PCV valve internals removed (I've had both). With the PCV valve in the noise will be a repetitive squeak, without the PCV valve it's a whirring noise.
Old Jun 16, 2007 | 05:55 PM
SpitfireS's Avatar
The "bottleneck" is the one reason to keep it in line.
The OEM PCV valve, IMO, also acts like a metering valve and only lets a fixed amout of air flow through, IOW it regulates.
There have been reports of failing spark plug coil seals with KrankVents.
Oil builds up around the sparkplug and may cause a short in the coil.
Keep your eye on them.
It's an easy check every now and then.
Old Jun 16, 2007 | 07:21 PM
fperra's Avatar
I've always run mine with the PCV valve gutted. It works fine. But keep in mind that the PCV valve is a non linear check valve. It meters the flow up to a point before it closes.
Old Jun 17, 2007 | 01:31 AM
SpitfireS's Avatar
Found it here:
http://www.stealth316.com/2-krankvents.htm
Are there any see-through pics of the Krank Vents?
Or is that a secret?
s2konroids
Jan 26, 2011 01:18 PM
abv
Mar 12, 2007 10:33 PM
cthree
S2000 Service Bulletins (TSB)
Mar 12, 2005 09:57 AM
BAKINBLK
Apr 19, 2004 02:20 PM
