Removing AC
Old Dec 22, 2005 | 09:40 AM
Asura's Avatar
Default Removing AC
Apparently, I need to remove the entire AC system. Is there anything I need to be aware of, and is there an appropriate method, that is environmentally kosher, to dispose of the R134.
Any help/hints/tips appreciated.
Thanks.
Old Jan 2, 2006 | 09:48 AM
jd2131's Avatar
To Remove the R134 in the enviromently "kosher" way i think you will have to take it to a shop that can capture it. (I think most shops should have a machine that does that). They should be able to get the system mostly empty for you, so you can hack away at your ac lines with a clean enviromentle conscience.
Old Jan 2, 2006 | 12:55 PM
Slows2k's Avatar
R134a must me recovered by law, most shops will have a minimal fee for doing this. It's only a matter of attaching 2 hoses to a recovery machine, open 2 valves and push "recover" The equiptment is the expensive part. Most machines run 3-6K
Old Jan 3, 2006 | 07:56 AM
Squeezer's Avatar
R12 has to be recovered by law. R134a is enviromentally safe and you can suck it out with the appropriate pump and discharge it into the air.
for the pump http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=92475
for the required guage set to connect to the r134a high and low pressure service ports http://www.harborfreight.com/cpi/ctaf/Disp...itemnumber=2435
Old Jan 3, 2006 | 09:46 AM
Asura's Avatar
Thank you gentlemen for all the helpful advice
Old Jan 3, 2006 | 05:03 PM
Slows2k's Avatar
It's still unlawful to discharge R134A to the atmostsphere. You won't find any reputable shop that doesn't recover.
E4RTH WORM JIM
Jul 2, 2016 03:04 AM
1derful
Jul 29, 2014 01:00 PM
ack5252
Jan 1, 2013 10:53 AM
Dst-s2
Aug 26, 2010 05:30 PM
sookie626
Jun 24, 2007 10:06 AM
