removing bellhousing help please!
Old Dec 11, 2011 | 11:49 AM
westfield147's Avatar
Default removing bellhousing help please!
feel like Im asking a stupid question-but my bellhousings got the better of me.
wondered if Ive missed something, cos it isnt coming off.well it comes off about a cm and then thats it...
Ive taken off all the bellhousing bolts.removed the clutch arm thingy, and the input shaft support, so whilst looking inside the bellhousing theyres nothing really to see, (other than a little blanking plate in the top corner, but that does lead anywhere).
when I try to pull the bellhousing off i get roughly a cm and thats it. feel like im forgetting something and when I try to pry it off, the resistance gets me worried that Im going to damage something inside the box... did I forget anything?what about the gear lever shaft?something else?
thought it was a case of bolts off, and yank it off!
would really appreciate it if someone could help me.
many thanks
Old Dec 11, 2011 | 11:52 AM
Stratocaster's Avatar
You have to remove EVERYTHING starting at the rear. The bell housing is part of the transmission case. It is not a separate part.
Old Dec 11, 2011 | 11:54 AM
holy crap! is there anything I should be worrying about taking it completely apart? what about internal gearing?
Old Dec 11, 2011 | 12:10 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Theres alot to worry about taking it apart that far. As stated, the trans needs to be completely gutted.
Why are you separating...shipping? broken bell housing?
Old Dec 11, 2011 | 12:34 PM
wanted to cut the bit out on the top of it, (clearance issues and weld a plate on). will still do it, but with the box as whole.
cheers guys, you just saved me a lot of time-just wished Id asked a few hours ago!
AaronSaya
Jun 23, 2021 05:53 AM
Vincegoehn
Feb 12, 2011 09:05 AM
Opc
Jul 9, 2010 06:22 PM
R2MUL
Car Talk - Non S2000
Apr 12, 2009 05:37 AM
s2kVTAK
Apr 10, 2009 09:52 AM
