Main Relay removal help!
Old Mar 3, 2019 | 01:43 PM
AaronSaya's Avatar
Default Main Relay removal help!
I've been trying to replace the main relay to narrow down some issues im having with the car. So i located the main relay but the problem is i dont see how it comes off... I dont see any tabs to push or anything and i dont wanna just yank it out. So if anyone who has replace it before and could tell me how to remove it that would be great!
Old Mar 3, 2019 | 02:56 PM
snitm's Avatar
Assuming you're referring to the PGM-FI as the main relay. There is a metal bracket that clips into the relay, and then a screw is used to hold the bracket and relay in place. Just remove the screw and disconnect the connector (order doesn't matter)
Old Mar 3, 2019 | 05:13 PM
AaronSaya's Avatar
So i should be able to pull the relay off the metal bracket? I tried to reach in with a socket to get the bolt but its too tight
Old Jun 2, 2020 | 01:12 PM
LewKeim's Avatar
Pry the insides out of the relay.
Old Jun 23, 2021 | 05:53 AM
RolanTHUNDER's Avatar
What issues were you having with the car and did a new (or repaired relay) solve them?
richmc
Feb 18, 2019 04:37 AM
Jake Johnson
Oct 26, 2018 12:22 PM
bgoetz
Jun 14, 2018 05:55 PM
BadgerS2000
Jun 13, 2018 04:26 PM
canuckr
Jun 20, 2016 11:45 AM
