Removing differential question.
Old Jan 24, 2020 | 05:21 AM
Slowcrash_101's Avatar
Default Removing differential question.
Can you remove the diff with the big diff mounts attached to the car?
I can't unbolt the passenger side mount because one of the bolts is cross threaded in. Only way to remove the bolt is to destroy something. Can the diff be removed without removing that diff mount or is cutting my only way forward?
Old Jan 24, 2020 | 06:49 AM
Having thought about it, yes it can be done. The brackets that attach the diff to the mounts is removable.
Old Jan 24, 2020 | 07:05 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I remove the 4 17mm head nuts on the back of the dif. The rear large mounts and the aluminum cross bracket stay in the car.
Old Jan 24, 2020 | 08:48 AM
Thank you good sir.
JoePhotographer
Apr 30, 2019 04:34 AM
Kinesis 996
Vancouver Island
Aug 9, 2018 12:03 AM
02AP1S2000
Jul 27, 2018 09:41 AM
Antonov
Jul 25, 2018 05:33 PM
DavidNJ
Apr 21, 2017 04:30 AM
