Removing soft top. Canvas only?
I would like to remove my soft top but then take the canvas part of it off of the frame of the soft top. is this possible or is it all sewn together?
thanks
-TK
thanks
-TK
I just did this job last weekend.
Yes, you can take the soft top off, and just leave the frame...why one would do that I have no idea. Are you planning to replace the top?
Or are you getting a hardtop and want to sell the soft top...that sounds more likely.
The soft top is riveted in 17 places. 2 up front to the frame for the tension wires, 4 behind the windows riveted to the frame, and 11 to rivet it to the rain rail (top can be removed without taking out these rivets). Taking out the rivets is easy...just a 5/32 drill bit.
There are also 16 screws under the weatherstipping and 2 more for the tension wire's spring. Also 11 10mm nuts in the back.
You can probably take the top out in 3-4 hours. I did it in 2 with a knife tho
If you pull the roll hoops out, it's cake, and the top will be intact.
Wanting to do this soon...
