check engine light ... help
Old Jul 11, 2011 | 07:03 AM
ForkYou's Avatar
Default check engine light ... help
Got in my car this morning and a check engine light came up
The code is P1457
Any idea what could cause it to come up ?
I just tightened the gas cap and started the car up and the light is still on , how many cycles does it take to clear if that was the problem ?
Old Jul 11, 2011 | 07:54 AM
whippets2k's Avatar
Is this an AP1? If so there were some issues with the filler neck, you need to grip the outside of the cap and turn to ensure it's tight. The light should go off after a few rides.
If I don't turn the outside of the cap on my car properly then I will get a code.
Old Jul 11, 2011 | 08:11 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
P1457 has nothing to do with the gas cap.
Find my P1457 DIY, and you'll be good to go.
Old Jul 11, 2011 | 09:35 AM
Billman250's Avatar
Top Answer: 1
P1457 fix:
https://www.s2ki.com/s2000/topic/851..._fromsearch__1
Old Jul 11, 2011 | 12:42 PM
ForkYou's Avatar
Thanks alot ...: also it's safe to continue driving my car till I get it fixed right ?
Old Jul 13, 2011 | 06:20 AM
ForkYou's Avatar
JonCraig
Jul 28, 2018 10:07 AM
Whitey_S2K
Sep 25, 2009 02:11 PM
jdmgpw04
Dec 2, 2008 08:26 PM
SLD2000
Oct 30, 2002 08:01 PM
yogi
Nov 6, 2000 04:24 PM
