Replace retainers and keepers
Old Mar 19, 2020 | 08:23 AM
yamaha6611's Avatar
Default Replace retainers and keepers
Just swapped out some titanium ones back to stock ap2 stuff...
Do I need to do a valve adjustment?
Old Mar 19, 2020 | 08:26 AM
cgarrett23's Avatar
It would definitely be a good idea to check your clearances.
Old Mar 25, 2020 | 06:41 AM
Pinky's Avatar
Cam's coming out and going back in doesn't change the clearance. Though, it wouldn't be a bad idea to go ahead and at least check them.
Old Mar 25, 2020 | 06:59 AM
Chuck S's Avatar
Seems pointless to NOT check the valve lash as the valve cover is already off and prudent to check them regardless of the cam removable not, in theory, changing any clearances. Decades ago I bent a pushrod in my then new SS396. Only found that one was bad. 16 new pushrods went in and valve lash checked as both heads were off.
-- Chuck
Old Mar 25, 2020 | 07:08 AM
flanders's Avatar
You should back out all the adjusters before removing the camshafts, otherwise you will risk cracking the cam caps.
It sounds like you already did the swap now but it's probably a good idea to check the clearance either way.
Old Mar 25, 2020 | 03:38 PM
miloking's Avatar
Why??? You know they are wearable item now that needs to be changed... If you just used ap2 ones those are for life of engine
kgf3076
May 22, 2019 02:47 PM
SideWaysOnFire
Jun 6, 2018 03:56 PM
freq
Apr 12, 2018 12:10 PM
Jgrady
Apr 12, 2018 10:58 AM
frenchy
Mar 14, 2017 12:15 PM
