Replaced Strike Plates in MY01
Old Nov 5, 2005 | 02:27 PM
530s2k's Avatar
Default Replaced Strike Plates in MY01
Install is very straightforward-- go ahead and take off the center piece of plastic where the overhead light is as well; only takes 5 extra minutes and makes everything easier.
Worthy of note: Sun visor screws were barely finger tight. Strike plate screws the same. I can't believe they hadn't rattled their way out yet.
Here are the pictures of my old striker plates. No wonder I couldn't hear myself think @ 60mph.
Driver Side
Driver Side
Driver Side
Passenger Side
Passenger Side
Old Nov 6, 2005 | 10:24 AM
boyguan's Avatar
i dont quite see how this would affect the sound that much
if you pulled down the top all the way then lactched it should catch in the hole
it seems like it didnt grab and slipped a few times to get those marks
Old Nov 6, 2005 | 10:48 AM
VR4's Avatar
VR4
thats what mine look like.
Old Nov 6, 2005 | 12:48 PM
530s2k's Avatar
Those marks come from the hooks compressing the metal over time. They absolutely effected the sound. The only noise going 75mph on the freeway now is tire noise. Before I couldn't have held a conversation with someone next to me.
Old Nov 6, 2005 | 03:05 PM
steven975's Avatar
yea, the sound is vastly improved.
Old Nov 7, 2005 | 09:33 AM
VR4's Avatar
VR4
got part numbers? my GF works for the honda dealer. ill send her the part numbers to pick them up.
Old Nov 7, 2005 | 09:39 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I think you are spot on with the noise issue
Good post...
Old Nov 7, 2005 | 03:40 PM
Inlands2k's Avatar
do you have the part number? i might just do what you did! i get lots of noise also.
Old Nov 7, 2005 | 03:46 PM
dmfitz82's Avatar
Did you use hardtop strikers or did you just replace with the regular ones for the soft-top?
Old Nov 7, 2005 | 04:14 PM
530s2k's Avatar
http://www.hardtopguy.com/store/customer/p...0&cat=92&page=1
I'll see if I can find the part #.
These are the hardtop striker plates, which is also what is used on the '02 (i think) and newer cars (even with soft tops).
