Replacing conrod bearing shells without removing oil pump, possible?
Old 08-02-2015, 02:02 PM
NardDog's Avatar
Default Replacing conrod bearing shells without removing oil pump, possible?
Hey guys.
I'm wondering if it's possible to replace the main end bearings for cylinder 1 and 2 without removing the oil pump, and if anyone has any tips to achieving this.
I've been able to get to 3 and 4 without problem but 1 and 2 are kinda hard to get to and I don't want to damage anything.
Thanks
Old 08-02-2015, 03:30 PM
Slowcrash_101's Avatar
Rod bearings yes mains no.
Old 08-03-2015, 12:31 AM
NardDog's Avatar
Thanks man.
I got the shells off tonight and some of them were pretty bad, but none bad enough to explain the amount of metal in my sump So I'm guessing it must be my mains.
The sound wasn't that bad I thought I'd caught it early.
Old 08-03-2015, 03:04 AM
Have you checked the camshafts as well?
Old 08-03-2015, 04:52 AM
windhund116's Avatar
Received 1,439 Likes on 965 Posts
OUCH!!!
Did you momentarily starve the engine of oil?
Old 08-03-2015, 06:10 AM
Billman250's Avatar
Received 1,269 Likes on 775 Posts
That is not from the camshafts, guaranteed.
Old 08-03-2015, 08:59 AM
MM3Kwolik's Avatar
That first one is gone. You have only the steel backing remaining. Either way, that whole motor needs to come apart and be rebuilt. Where are you located?
Old 08-03-2015, 10:04 AM
NardDog's Avatar
I agree, the bearings will get replaced, but there is obviously something else failed.
I really wanted to get this done without pulling the motor. I don't really have the time or space to sort this. I'm from Europe buddy.
Old 08-03-2015, 10:41 AM
How does the crankshaft look?
Old 08-03-2015, 11:07 AM
NardDog's Avatar
Crankshaft is really good, surprising really. I only noticed one tiny belemish which should easily polish out.
I'm tempted to throw some shells on her and see how she runs. This is my first time in the bottom end of an engine so perhaps I'm being naïve. I've read that the collection in the sump could be the shells as they clump together?
My DIY skills are running dry on this one. I really don't want to give it to a shop just yet though.
Quick Reply: Replacing conrod bearing shells without removing oil pump, possible?
