Replacing input shaft seal
Old Jun 24, 2010 | 04:15 PM
nin10dough's Avatar
Default Replacing input shaft seal
So i followed the Helm's and the sticky here on the boards to take of my tranny. Now that it's off, how do i go about replacing the seal? It looks as though it's installed from the inside which means I have to take the entire tranny apart? Is there any other way to do this?
Old Jun 24, 2010 | 04:46 PM
Slows2k's Avatar
It is installed from the bellhousing side. The throwout bearing retainer must be removed.
There is a Honda special tool used to drive the seal into the housing over the input shaft.
Maybe if you ask a dealer nicely they will let you borrow it.
Old Jun 24, 2010 | 05:15 PM
nin10dough's Avatar
Good to hear! I hope this special tool can remove the old seal from the bellhousing side as well. It does not look like a pleasant job if you're going to follow the helm's manual to remove it...
Old Jun 24, 2010 | 05:27 PM
Slows2k's Avatar
With the OEM seal driver it's a few minutes to install it, after removing the trans
The S2k trans is the only Honda manual trans that you can do this with. All the FWD trans require you to split the case and pull the shafts out to get to the seal.
Old Jun 24, 2010 | 05:38 PM
nin10dough's Avatar
That was my first impression as well looking at the seal. it doesn't look like it can pull out easily.
Not sure how this driver tool will pull out the old seal but it's something that I'll be purchasing tonight.
In case anyone else needs to purchase these two parts, Below is the part numbers. It's also referenced in the Helms manual.
07749-0010000 DRIVER HANDLE
07746-0010300 ATTACHMENT (42X47MM)
Old Jun 24, 2010 | 06:18 PM
thatsahonda's Avatar
how much is the tool?
Old Jun 24, 2010 | 06:37 PM
nin10dough's Avatar
Here you go.
07749-0010000 DRIVER HANDLE - $16.72
07746-0010300 ATTACHMENT (42X47MM) - $16.00
shanepotter
Sep 25, 2015 04:11 PM
Opc
Jul 9, 2010 06:22 PM
2QYK4U
Mar 16, 2008 06:33 PM
lude9285
Oct 10, 2007 11:45 AM
