Replacing Outboard CV Boot
Old Jun 26, 2014 | 05:26 PM
ViperASR's Avatar
Default Replacing Outboard CV Boot
So I discovered a tear in the outboard CV boot on the drivers side. A small tear, just enough to fling a little grease on the caliper and control arm. Didn't even get any on the wheel.
Does the axle nut need to be removed, or is there a way to pull the CV from the hub and replace the boot?
Thanks!
Old Jun 27, 2014 | 07:10 AM
ktwenty's Avatar
Remove the cv joint from the hub also you will have to separate the inner cup from the diff, take the complete axle out and cut the old cv boot out of the way, using a brass hammer you will have to tap out the joint the rest is straight forward
tozerman
May 26, 2016 02:53 AM
miskatcitnamor
Aug 23, 2014 08:27 AM
dagger
Jul 21, 2012 02:07 PM
IntegraR0064
Jun 13, 2011 07:43 PM
Asura
Jul 22, 2005 05:45 AM
