Retrofitting OBDII port into s2000
Old Jul 19, 2008 | 03:43 AM
ncmx5's Avatar
Question Retrofitting OBDII port into s2000
Can it be done? A retrofit of the OBDII port into s2000?
The Australian model's don't have OBDII ports but i want to plug one in so i can hook up the scangauge to keep an eye on things.
Where does the US s2k's OBD wires lead to?
Old Jul 19, 2008 | 04:11 AM
NVMY4N's Avatar
r u sure......
did you look? and if you did where did you look
Old Jul 19, 2008 | 04:13 AM
ncmx5's Avatar
def sure, looked under passenger footwell. i can show you a photo if you like. Searched the whole forums - other aust owners don't have them. Apparently they're to do with F20C1 (aus) or F20C2 (us) or something..
Old Jul 19, 2008 | 04:35 AM
NVMY4N's Avatar
very strange.....
Im stumped.
sry
Old Jul 19, 2008 | 06:25 AM
roflitzjinno's Avatar
i thought all cars 95+ had obo2?
Old Jul 19, 2008 | 06:32 AM
Hondassport's Avatar
I think that is tru only in the USA, the OP is in Australia.
Old Jul 19, 2008 | 06:35 AM
Stratocaster's Avatar
It will take two parts to install ODBII. First you need a wiring harness. (I have a spare if you are interested). I would guess that you need a new ECU.
To install, you will need to remove the dash. That harness is behind the dash and tied to a number of other things back there too.
Old Jul 19, 2008 | 06:52 AM
ncmx5's Avatar
so how many connectors does the harness have? i may be interested in that spare if i figured out the processes of installing it successfullly.
from the pics ive seen thru the forums, our ecu looks similar to yours, with 3 plugs going in. i read there's prob only a couple of wires diff....
Old Jul 19, 2008 | 07:30 AM
What is the part number of your AU ECU?
Old Jul 19, 2008 | 09:42 AM
Elistan's Avatar
Some years have it in the drivers footwell.
