rev limiter question
Old Nov 11, 2004 | 06:29 PM
Qwik 1's Avatar
Default rev limiter question
Does the rev limiter on these cars take away fuel or do they take away spark?
I would not want to go lean at 9000 rpm. Thanks for any input.
Brian
Old Nov 11, 2004 | 06:37 PM
supaman's Avatar
Fuel cut off, if i'm correct.
Old Nov 11, 2004 | 06:44 PM
xviper's Avatar
Almost all cars with a rev limiter will use some kind of fuel cut-off. Some may also incorporate an ignition kill. Since this is the case with all these cars, why are you so worried about yours? Suddenly shutting off the fuel at 9000 rpm is not quite like running "lean". You need "some" fuel to run lean. Having no fuel would result in no combustion. With no combustion, you can't run lean. You're just shoving air in and out of a pump.
Having the fuel shut off is not much different than you taking your foot off the gas pedal. In fact, every time you take your foot off the gas pedal to decelerate, the fuel shuts off. I think you are worrying about something that's very normal and inconsequential.
TonysMI4
Aug 29, 2011 10:10 AM
joefish1298
Jul 21, 2010 06:15 AM
s2000Junky
Sep 24, 2008 12:09 PM
juice04
Jul 13, 2006 01:41 PM
Bada Bing!
Feb 21, 2005 03:43 PM
