ricks or j's 4.44 gear
Old Sep 5, 2003 | 12:59 AM
  #41
vapors2k's Avatar
Originally posted by Defender
Could you explain that process or provide a link to an explanation. Are you talking about tempering the metal ? I am just thinking that the metal was molten when it was cast - so it was pretty hot then, and we obviously are not going to get it that hot while running it in the car - so what are we doing when we drive gently so as not to get the metal too hot ?
when the unit is installed, it's installed to certain tolerances or specs. These specs aren't permanent and can change until a certain number of heat cycles where things settle in there. That's why you don't want to drive the car hard and want to let things heat cycle normally and gradually get them to the point where you are shifting faster and inducing more heat to the rear end. I would say that 2 tank fulls of gas in terms of milage (driving on the hwy at steady speed doesn't really count, more like city miles) should be an adequte amount of miles to consider the gears "broken in." Remember it's not the metal of the gears that needs heat cycling but the entire unit as a whole as it's assembled with bolts and nuts to specific tolerances. Too much heat will cause things to expand in there and change the clearances as the metal expands under heat.
Old Sep 5, 2003 | 06:18 AM
  #42
Gernby's Avatar
Former Sponsor
Break-in suggestions.
https://www.s2ki.com/forums/showthread.php?...threadid=143776
Old Sep 5, 2003 | 06:20 AM
  #43
Gernby's Avatar
Former Sponsor
I guess that link died. Here is the new URL:
http://www.ring-pinion.com/tech/techg0698.html
Old Sep 5, 2003 | 09:44 AM
  #44
Defender's Avatar
[QUOTE]Originally posted by gernby
[B]I guess that link died.
Old Sep 5, 2003 | 06:18 PM
  #45
trich1687's Avatar
I just, and I mean just ( my fingers are still greasy) finished the 4:77 install on my car. I dropped the diff and brought it to a pro to do the ring & pinion install. Just put the diff back in tonight and did my first 7 mile heat cycle. I found the same post on the net about the oil temp and I am convinced the more I read on the topic that proper break in is critical. I will be doing several short heat cycles tomorrow and take it real easy for a few hundred miles. I will repost when it's safe to romp on it with my impressions. The installed only charged me $ 100 , Yes he is a pro and has done lots of Ring & pinions setups
Old Sep 5, 2003 | 08:25 PM
  #46
tenblade2001's Avatar
I got the last 4.44 and they are being installed now, along with the tranny/clutch TSBs being done....can't wait to get the car back. Rick and Strat, I hope the deal goes through. If it does, that will be great!
Old Sep 5, 2003 | 08:29 PM
  #47
Stratocaster's Avatar
[QUOTE]Originally posted by tenblade2001
[B]I got the last 4.44 and they are being installed now, along with the tranny/clutch TSBs being done....can't wait to get the car back.
Old Sep 6, 2003 | 02:53 AM
  #48
Defender's Avatar
Originally posted by Stratocaster
I hope you enjoy them. As for the "deal", the only thing missing is the ink it should be somethime this week.
Is that deal just going to be on the 4.44's or will it encompass the 4.77's too ??
Old Sep 6, 2003 | 03:28 AM
  #49
4.44 and 4.77 (I think)
Old Sep 12, 2003 | 10:45 AM
  #50
tomSS2000's Avatar
So? Any new announcements about the 4.44s Rick? I've Been waiting patiently .
