Rick's oem installation part kit
Old Jul 26, 2004 | 03:08 PM
bunjimobile's Avatar
Default Rick's oem installation part kit
I decided to purchase the Rick's 4.77 polydyn treated gears for $400. now problem is do I really need to purchase the oem installation part kit in order to install the gears? Can it be installed without the oem installation part kit and just use what's on the car now?
Old Jul 26, 2004 | 04:56 PM
xviper's Avatar
The OEM parts kit is a good bargain. It contains almost all the parts that should be changed when you do this job. The bearings will most likely be damaged in the dismantling.
Old Jul 26, 2004 | 05:19 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I've done a few s2k ring and pinoin installs. Get the kit.
Old Jul 27, 2004 | 02:23 AM
alrighty then...thanks guys!!
Old Jul 27, 2004 | 06:07 AM
Gernby's Avatar
Former Sponsor
Depending on your mileage, you should also consider getting the side bearings and oil seals.
Old Jul 27, 2004 | 01:48 PM
well it's an 2001 model and I only have about 31,000 kms or 18,600 miles.........I drive the car like aprox. 11,000 kms or 6,600 miles a year. I should be ok with the side bearings and oil seal....either ways I'm sure the mechanic will notice if anything needs attentions during the installation. Thanks for the heads up though
Old Jul 27, 2004 | 02:01 PM
Gernby's Avatar
Former Sponsor
In that case, you may still want to replace the side oil seals due to age. They are cheap.
wadzii
Feb 2, 2015 11:21 AM
stinky_finger
Dec 20, 2012 07:56 AM
