Rocker arm piston?
Old Jun 21, 2023 | 02:00 PM
  #31
windhund116's Avatar
Originally Posted by Kyle
It has been done tons of times at this point, and is well-documented.
Updated Must Haves for K Swapping A Honda S2000 | Speed Academy
There's tons and tons of ways to do this; either the boujee way aka buying headers & intake manifold made for kswap s2000s, OR just cutting the flanges off of both and welding on K flanges. Personally, I'd keep the stock header and just cut off the flange and weld on one for a K. For the intake manifold I'd absolutely go with the Kpower Industries one: https://kpower.industries/collection...ntake-manifold
It has all of the provisions for your IACV, throttle cable, etc, and has the bolt pattern for your throttle body (B/D/F/H).
Aftermarket ECU is not required - you'd just need to make some modifications to the wiring. People sell custom harnesses or jumpers, but realistically the best and cheapest way is to just get a wiring diagram and figure out what needs to go where and what connectors need to be changed etc.
I will NEVER spend 5-7k on someone's tired ass second hand F series with 100k miles on it....As these cars continue to age and replacement engines become harder to source I simply cannot understand why people shell out bookoo money to replace the motor unless they're trying to keep the car "authentic". The K is arguably the better engine anyway.
Did you or someone you know, do a K24 replacement? How do you get the car certified so that you can get it registered --- to be able to drive it on the street?
Merci beaucoup!
Old Jun 21, 2023 | 04:15 PM
  #32
ShellKace's Avatar
yeah ive swapped the engine once with a F series. and thats this motor. i paid 2.8k with transmission and lasted 3 years still it shitted on me.
again the whole harness would probably be the hardest thing for me to figure out. as i AM WORTHLESS with wiring. and even trying to read a diagram. so id probably be able to do the rest if i did extensive research but i honestly need someone who has done this before to walk me thru this whole process. as i know issues with arise.. during installation. well see.. i know a K series is so much cheaper and i wish i can do this with ease.
Old Jun 21, 2023 | 06:24 PM
  #33
B serious's Avatar
K swaps are not all up-sides. There are negatives as well.
There are a lot of up-sides to keeping the F series. Not just for originality.
I disagree that the K is a better engine.
It has a better head design, however. And its dirt cheap. Don't get me wrong, it is genuinely an excellent engine. But...no...its not a better engine than the F series (without adding some kind of qualifier to that statement).
I would do objective research before diving into a K swap.
OP, you haven't found the root cause of your problem with your current F series. Its likely going to stem from someone doing something incorrectly. Would you agree?
Your original engine failed because someone forgot to put oil in it, right? The K series is not immune to that either.
This is probably gonna sound harsh...but the pattern of issues follows your attempts to keep rebuilding the engines with sub-optimal parts.
If you had bought a box-stock F series and swapped it in and kept oil in it...it would probably run until the end of time.
Old Jun 21, 2023 | 06:42 PM
  #34
B serious's Avatar
However, if you do want to do a K swap, ASMotorsports sells packages where you don't need to do anything except drop it all in.
Old Jun 21, 2023 | 08:46 PM
  #35
What RPMs does the K24 redline at?
Thanks!
Old Jun 25, 2023 | 05:52 AM
  #36
Slowcrash_101's Avatar
I wouldn't spin them more than 8,000, that's like 9,100 on an F20.
Old Jun 25, 2023 | 08:46 AM
  #37
B serious's Avatar
Thanks!
Something like 7200 in stock form.
8K after installation of a type S oil pump. But it would vibrate everything to the point of potentially breaking parts.
And it would have an abbreviated life span.
I've had a couple K20 and K24 swapped and stock K series cars. The beauty of a K24 is NOT needing to rev it. Most people only stretch the shifts to 8K when absolutely needed. Buy a K20Z or K20A-R if you wanna rev it.
Again...an excellent overall package and a lot of the downsides can be mitigated thru expertise. But...I wouldn't go out of my way to K swap a S2000 to "cure" it or something.
ShellKace
Jun 16, 2023 09:20 AM
Importedpower
Feb 19, 2013 10:39 AM
xx_treva_xx
37
Jul 2, 2009 09:59 PM
aero3685
Apr 10, 2007 08:22 PM
Dylan Hunt
38
Mar 13, 2006 03:44 PM
