Rotation Noise on Freeway
Old Jan 26, 2010 | 10:13 PM
Thanhstar's Avatar
Default Rotation Noise on Freeway
The other night i noticed when i step on the gas from 65+ mph the car would make a rotational noise from the rear (low humming sounds) but i will jack up the car tomorrow and take a look.. i can only feel it under load at freeway speeds, driving in the streets i do not notice a difference any ideas?
Old Jan 26, 2010 | 10:33 PM
CapoArgentino's Avatar
Banned
Define rotational noise? Also, how many miles on the s2?
Does it sound like THIS?
There are other S2000 noise videos in youtube you might want to check and compare but we definately need more info from ya.
Old Jan 26, 2010 | 11:17 PM
Thanhstar's Avatar
well i can only hear it when i give it accel.. its a low pitch humming rotation sound, and the faster i go 70+ it gets louder, and the rotation seems to get faster..
Old Jan 26, 2010 | 11:22 PM
S2Kmonkee's Avatar
maybe it's the bearing, when the car is up. See if your wheels wobbles or has any play in them. Good luck
Old Jan 27, 2010 | 12:05 AM
Bewbies's Avatar
How bad did you hit the brakes? You might have put a flat spot on the tires I did that once when I locked them up on the freeway to avoid an accident.
Old Jan 27, 2010 | 04:24 AM
dammitjim's Avatar
Check your lug bolts. If they are fine you might ask the shop to rebalance your wheels. It's possible you threw a weight.
Old Jan 27, 2010 | 12:22 PM
Thanhstar's Avatar
Wouldn't a bearing be consistant? I feel it on accel 50+ mph
Old Jan 27, 2010 | 10:01 PM
Thanhstar's Avatar
at this point it may be the wheel bearing or worst case the diff.. but i didn't launch my car, clutch drop...
Old Jan 27, 2010 | 11:32 PM
S2Kmonkee's Avatar
Diff tends to go out randomly at times. They're not as strong as they're suppose to be. I read that on some other threads. Why don't you try changing the diff fuilds and see if anything broke in there.
Old Jan 27, 2010 | 11:51 PM
Thanhstar's Avatar
im planning on changing the fluid this weekend, i dont hear any clunks or any harsh sounds... its just a low tone hum
