Rotors are stuck
Old Sep 2, 2010 | 03:03 PM
mrbond413's Avatar
Default Rotors are stuck
I'm tryig to pull my rotors so I can turn them but they won't come off. I've searched the forum and I seem to be having the opposite problem of everyone else. I pulled the wheels and calipers off and the 2 screws holding the rotor in place came out easily with a screw driver. The problem is that the rotors are stuck to the hubs on all 4 wheels. Did I miss a step that I'm just not seeing? I've tried beating on them with a 3lb sledge using wd40 an kroil but still nothing. There are also 2 other holes for pushing a bolt through to push the rotor off but I don't know what size they are an I don't have a rotor to take to the hardware store to figure it out. Does anyone know what size they are?
Old Sep 2, 2010 | 03:05 PM
s2k dre's Avatar
Keep hitting them with a hammer, they will come off.
Old Sep 2, 2010 | 03:09 PM
cpl_allen's Avatar
Someone also posted a powerpoint type thing about turning rotors and how they can decrease braking unless they are turned slowly and sanded flat
Old Sep 2, 2010 | 03:28 PM
RedY2KS2k's Avatar
There are two threaded holes in the rotor, between the tapered holes that you removed the Phillips screws from.
Get a pair of M8 x 1.25 bolts at any auto parts store, hardware store, maybe even Lowe's or Home Depot. Thread one into each threaded hole. Turn them a little bit, alternating between the two to keep the force they exert even. They'll push against the hub and remove the rotor.
Old Sep 2, 2010 | 03:30 PM
RedY2KS2k's Avatar
Sorry, I didn't read the original post carefully enough.
The holes have M8 x 1.25 threads. If the bolts you buy are DIN (Euro and American) they'll have a 13mm hex head. If they're JIS (Asian) the head will be 12mm.
Old Sep 2, 2010 | 03:40 PM
chubbychu's Avatar
I've been re-looking for that for a LONG time.
Old Sep 2, 2010 | 03:41 PM
mrbond413's Avatar
Thanks for the info redy2ks2k and thanks for the heads up Allen, I will make sure to turn them slowly and sand them flat. Normally I wouldn't turn the rotors but the back side of the front rotors are a little worn and it gets pretty shaky when braking at 50mph+. This will be the first time they have been turned and I don't think I will have to go to deep into them.
Old Sep 2, 2010 | 04:29 PM
Opc's Avatar
Opc
when SMACKING them with a sledge hammer, hit the top HARD, hit the bottom next, HARD, hit the top left HARD, bottom right, HARD. enjoy
Old Sep 2, 2010 | 05:14 PM
jeggy's Avatar
then go buy new rotors because you just bent/warped/divoted the thing by wacking it with a hammer.
Old Sep 2, 2010 | 05:50 PM
INTJ's Avatar
Yes! And hit the thing hard from an angle with a rubber mallet. Ignore the other posts..
