Rough clutch only when car is on
Old Aug 25, 2018 | 07:48 PM
windhund116's Avatar
" The Exedy kit is crap."
Unfortunately, yes.
Old Aug 26, 2018 | 04:57 AM
Car Analogy's Avatar
At 25k on the kit, you have exceeded the life expectancy of an exedy clutch. Plan to drop trans, and replace all.
Disk
Release bearing
Release bearing guide
Pilot bearing
Pressure plate
Old Aug 26, 2018 | 05:02 AM
Nfinitecc's Avatar
The jobs not bad, I wasted a lot of time putting the job off because I thought it was gonna be a pain, it wasn’t bad at all.
Old Aug 26, 2018 | 05:04 AM
jiepo's Avatar
I want to get it done properly while everything is out.
I've read good things about an ACT PP + OEM clutch combo. I'll also go with all OEM release bearing and guide, pilot bearing, clutch fork, resurface the flywheel, new hardware, and make sure everything that needs grease is greased well with Urea grease.
Old Aug 26, 2018 | 05:53 AM
Nfinitecc's Avatar
I would buy a new flywheel, most places won’t grind re-surface this stepped flywheel.
Old Aug 26, 2018 | 08:45 AM
B serious's Avatar
Buy a new release guide also.
blixhavn
May 1, 2011 11:47 AM
sean_f
Jan 9, 2009 12:06 PM
rikhemi
Sep 10, 2007 06:29 PM
ajkewler
Jan 9, 2006 11:36 AM
Big_Al
Nov 11, 2005 11:45 AM
