Rough Idle with EML light on.
Hi
After 5 hours of diagnosis. Clearing Fault codes and checking gas emmisions. I have found out there is a problem common to most rough idle S2000's---- INJECTORS. It does not show up on Gas emissions but show on the HDS reader as Cylinder Misfire Bit Codes. I also noticed that the Injector duration came down from 2.9 to 2.1 ms. The injectors cause bore washing and lower the compression on the engine which is critical to the running of the V Tec hence the rough idle. They cost about
Luisdiaz813
Apr 17, 2017 04:47 PM
riceball777
Jun 16, 2015 10:37 AM
