Rough Idle/Stalling
Old Jul 20, 2010 | 11:54 AM
essi1553's Avatar
Originally Posted by AP2NV,Jul 19 2010, 01:02 PM
After browsing the DIY sections, I will be cleaning the IACV today and also the map sensor and possibly doing the "wack" mod lol, thanks for the input guys, I will keep you posted, much appreciated!
This and a ECU reset should do the trick, I had the same symptoms when i first got the car too, oddly enough.
Later i changed the spark plugs, cleaned the throttle body. Make sure you do the proper ecu reset procedure, thats most important.
Old Jul 20, 2010 | 01:54 PM
AP2NV's Avatar
Well all last night and this morning the car ran perfect and smooth, today after my friend got out of class the car struggled again and at one point the car even stalled 6 times in one block. Would spark plugs help any? The car seems to not be misfiring or hestitating just can't hold correct idle.
Old Jul 20, 2010 | 02:08 PM
AP2NV's Avatar
Does anyone know if a 06 cat works on a 2000? If it does I can let him use mine and see if that helps or is the problem.
Old Jul 20, 2010 | 02:26 PM
keeblertime's Avatar
yeah, sounds like you have a bad IAC valve(motor), just go to the parts house and get you a new one, they're not the much, and installation is a snap.
Old Jul 20, 2010 | 02:33 PM
AP2NV's Avatar
Wouldn't a bad IACV eventually cause a CEL? Cause it has had no CELs at all
Old Jul 21, 2010 | 04:34 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If your problem is purely idle, I would still suspect the IAC.
It can very well show your symptoms, and have no CEL.
Old Jul 21, 2010 | 05:04 AM
CitadelBlue's Avatar
Originally Posted by Billman250,Jul 19 2010, 07:38 AM
First thing I would do is pull off the IAC valve and clean it.
For those confused .... check this post out:
How to clean the IAC Valve
Old Jul 21, 2010 | 09:41 AM
toniotran's Avatar
as the car is in the process of stalling be sure also not to apply any pressure on the gas and just let the car stall on its own, and hopefully the car should then run fine as the ecu should eventually learn on its own.
Old Jul 21, 2010 | 07:02 PM
AP2NV's Avatar
Ordered a new iacv assembly, if that doesn't fix it then the dealership will have to take it in...will keep everyone posted
Old Jul 23, 2010 | 06:11 PM
AP2NV's Avatar
New one installed and problems still exist and are noticeably worse when the ac is on, ecu was reset as well...any other suggestions?
