Rounded diff drain bolt. Any tips for removal?
Old Nov 23, 2015 | 01:51 PM
redwing497's Avatar
Default Rounded diff drain bolt. Any tips for removal?
Hey guys. Thought I could get it off now it's just rounded. 24mm socket won't grip. Any tips for me? Really need to get this thing off. Thanks.
Old Nov 23, 2015 | 02:42 PM
maaaaackle's Avatar
Don't you just hate that?
Maybe try wrapping a rubber band around the bolt and putting your box-end wrench over that? It's all about creativity at this point especially with an annoying bolt like the diff bolt.
Old Nov 23, 2015 | 03:07 PM
thomsbrain's Avatar
Are you using a 6-point socket, or 12? 6 will always grip better and is less likely to round things.
Might be able to get enough grip with vice grip pliers, too.
Old Nov 23, 2015 | 03:08 PM
cleenyc99's Avatar
^what he said
use a 6 point socket made in usa
Old Nov 23, 2015 | 03:20 PM
nissanfanatic's Avatar
Harbor Freight impact sockets are good too. They are six point and pretty thick wall.
Old Nov 23, 2015 | 03:24 PM
bendang2005's Avatar
I would suggest cutting a slot in the center and use a impact screwdriver to remove it. This means you'll have to replace the bolt.
Old Nov 23, 2015 | 03:35 PM
s2000ellier's Avatar
hammer a 23mm onto it
Old Nov 23, 2015 | 05:06 PM
MSTSH80's Avatar
last resort you can cut a slice into it with a cut off wheel, then use a skinny pry bar to break it free.
or u can use a chisel to break it free, put the tip of the chisel into the corner of the slot u cut and hammer it loose.
try the 6 point socket first tho. be careful in the future if your using harbor freight sockets or wrenches, cause they stretch and can cause stripping.
good luck!
Old Nov 23, 2015 | 05:26 PM
redwing497's Avatar
Thanks for the tips guys. I looked and it is indeed a 12 point socket. Damn. Do you think a 6 point will still grip it? The 12 grips but only barely.
Using the cutting method, are you saying cut like a small pie piece out of the bolt then use a chisel/screwdriver and bang it with a hammer?
Old Nov 23, 2015 | 05:31 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Use a 15/16 socket, 6 point.
It is .006 smaller and will work like a charm.
