Rust at Welds
Old Nov 26, 2023 | 01:27 PM
ecfreeride's Avatar
Default Rust at Welds
I took my gas tank out and noticed that there is some rust at weld locations and seams. Is the car rusting from the inside out? Or do you think this is surface rust that I can grind down and paint? Pictures below
Old Nov 26, 2023 | 01:56 PM
spider2k's Avatar
Active Streak: 30 Days
POR15
Old Nov 26, 2023 | 02:29 PM
zeroptzero's Avatar
spot welds are vulnerable , that is very light surface rust, nothing too serious. I would rustproof those areas or paint them as noted above. Definitely treat them to keep them from rusting further.
Old Nov 26, 2023 | 03:21 PM
B serious's Avatar
Its just surface rust. Welds are prone to that.
You can wire brush that off and POR15 it or something similar.
Look into "honey seal" or woolwax's "creep n crawl". Its a hardening wax that's similar to what is used at the factory inside of crevices. You can lay it all over the seams and welds under the car.
aw11
Jan 2, 2019 10:06 AM
Abysm
Jul 21, 2014 04:15 PM
fryetech
Apr 4, 2009 06:20 AM
TitusS2k
Apr 30, 2007 06:10 AM
Avionics86
Dec 20, 2006 07:32 PM
