Gas Leak?
After filling up my gas tank and driving home. Went inside for about a 1/2 hour.
Then went outside to go out to eat with the family and then I smelled gas.. I backed up my car and noticed a small wet spot..
I looked under my car and then I noticed a wet spot about a foot from the rear driver side tire.. I took pictures and attached them.
Is this normal and I just never noticed it??
Or what could be broken?
I've never experienced that before. And gasoline potentially dripping on a hot exhaust is asking for trouble.
I would get the car in the air and look to see where the leak is coming from.
Is there any gas lines around that area? It is no longer wet under there however I haven't driven it again.
Maybe I should drive it and see if there is still a leak?
Also I mite add after filling up. By mistake, I did hit my front end on the ground. Not sure if that makes a difference.
