S2000 alignment: Before/After
Old Oct 10, 2002 | 08:08 AM
  #41
jzr's Avatar
jzr
[QUOTE]Originally posted by gernby
[B]
That is normal, even with a good alignment.
Old Oct 10, 2002 | 09:32 AM
  #42
cbender's Avatar
I went to zero toe, front AND rear, and I'm very pleased with the greater feeling of stability. Turn-in doesn't seem too sharp or too numb, and the car now handles more neutrally... slight understeer at entry, progressing to neutral drift as the corner tightens, with power-on oversteer readily available. Specs are below. I don't have enough miles, yet, to determine how it's going to affect tire wear.
BEFORE
FRONT LEFT RIGHT
Toe 0.06 -0.25
Caster 5.50 5.70
Camber -0.50 -0.40
REAR LEFT RIGHT
Toe 0.20 0.38
Camber -1.50 -1.40
AFTER
FRONT LEFT RIGHT
Toe -0.02 -0.01
Caster 5.60 6.10
Camber -1.50 -1.50
REAR LEFT RIGHT
Toe 0.01 0.00
Camber -2.00 -2.20
Old Oct 10, 2002 | 12:26 PM
  #43
TSS2000's Avatar
[QUOTE]Originally posted by bbsilver
[B]
Mine were done at 10K and 15K, no track (at the time).
Old Oct 10, 2002 | 12:54 PM
  #44
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by jzr
[B]Negative camber, in and of itself, isn't what wears out your tires.
Old Oct 11, 2002 | 03:00 AM
  #45
jguerdat's Avatar
Confused question:
Tire Rack ( http://www.tirerack.com/tires/tiretech/com...on/racepres.htm ) and other say to move towards toe-OUT to reduce oversteer. I've always thought it was toe-IN that does it. Can someone explain this?
Old Nov 5, 2002 | 12:47 PM
  #46
bbsilver's Avatar
[QUOTE]Originally posted by TSS2000
[B]
where you done your alignment at?
Old Nov 5, 2002 | 03:04 PM
  #47
Windscreen's Avatar
[QUOTE]Originally posted by jguerdat
[B]Confused question:
Old Nov 5, 2002 | 03:21 PM
  #48
Gernby's Avatar
Former Sponsor
[QUOTE]Originally posted by Windscreen
[B]
I think Tire Rack screwed up front & rear on that page.
Old Nov 5, 2002 | 03:58 PM
  #49
Windscreen's Avatar
[B]
Toe out in the front should increase OVERsteer.
Old Nov 5, 2002 | 05:52 PM
  #50
Gernby's Avatar
Former Sponsor
[B]
But it is no different if the tires point away from each other...they still fight each other.
