s2000 engine reinstallation questions.
Old Apr 30, 2007 | 08:14 PM
custom_bimmer's Avatar
Default s2000 engine reinstallation questions.
so i finaly got a new engine to replace mine. the old engine and tranny are out of the car and i am ready to put the new one in. i have to connect my old tranny to the new motor (used motor that has the clutch already). how do i do this? do i need a clutch aligning tool?
i have a car lift.
Old May 1, 2007 | 03:37 AM
Popeye's Avatar
Hope this helps.......http://servage.hondahookup.com/manuals/Hon...ce%20Manual.pdf
Old May 1, 2007 | 04:14 PM
link would not open. still looking for help.
thank you.
Old May 1, 2007 | 04:25 PM
Atheist's Avatar
yes you will need to allign the clutch.
Take the trans bolts out, pull it off, pull the clutch, put it in well aligned, and put the gearbox back on.
If you dont know how to do any of these things beware as the swap itself will be much more difficult
Old May 1, 2007 | 05:26 PM
where do i get the tool? why do i need to pull the clutch if it is on the motor all ready.
Old May 1, 2007 | 05:33 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If the clutch is on the engine from removal, there's nothing to align.
Old May 1, 2007 | 05:34 PM
Billman250's Avatar
Top Answer: 1
The engine/trans assy will not fit in the car, unless the front subframe is removed.
Old May 1, 2007 | 05:39 PM
aero3685's Avatar
Your clutch is on the old motor correct? If so, you will need to put the clutch on the new engine which WILL require you to use the tool. I think Napa *may* have the tool. I know when I was searching for one, thats what someone told me.
And as billman said, you will have to put the clutch in, then put the motor in the car, then drop the crossmember, and then attach the tranny to the engine.
Old May 1, 2007 | 07:19 PM
squirrels2k's Avatar
it'll go in all together
Old May 1, 2007 | 07:25 PM
Slows2k's Avatar
It won't go in assembled from the hood opening, Unless you have the car 2 feet off the ground and can crane the engine and trans assembly over the car and hold them at a 45 degree angle.... Or you remove the subframe as Billman stated.
Pretty much won't go in.
Tried it, not worth the hassle, and can be done faster the normal way
