S2000 eps
Google is your friend
With the car off, and the wheel straight do the following
If the EPS light stays on, you will have to do this process again.
- Using a paper clip or backprobes, connect PIN 9 to PIN 4 on the ODBII connector.
- Turn the steering wheel 45 degrees to the left
- Turn the ignition switch on (II)
- The EPS Light will be on for 4 seconds, when it goes out do step 5
- Turn the steering wheel Straight, and release
- The EPS Light will turn on in 4 seconds, when it goes out do step 7
- The EPS Light will be on for 4 seconds, when it goes out do step 9
Where did you find this?
