S2000 eps
Old Jan 5, 2018 | 08:54 AM
qjb0607's Avatar
Default S2000 eps
how to reset 2000 Honda S2000 EPS
Old Jan 5, 2018 | 09:08 AM
Slowcrash_101's Avatar
Google is your friend
With the car off, and the wheel straight do the following
  1. Using a paper clip or backprobes, connect PIN 9 to PIN 4 on the ODBII connector.
  2. Turn the steering wheel 45 degrees to the left
  3. Turn the ignition switch on (II)
  4. The EPS Light will be on for 4 seconds, when it goes out do step 5
  5. Turn the steering wheel Straight, and release
  6. The EPS Light will turn on in 4 seconds, when it goes out do step 7
  7. Turn the steering wheel 45 degrees to the left
  8. The EPS Light will be on for 4 seconds, when it goes out do step 9
  9. Turn the steering wheel Straight, and release
now the EPS light will blink twice after you relase the wheel, within 4 seconds. then it will blink 5 times.
If the EPS light stays on, you will have to do this process again.
Old Apr 21, 2021 | 01:59 PM
stocky's Avatar
Is this a real procedure?!
Where did you find this?
eleven_b
Jan 5, 2018 09:41 AM
Fmj03
Jul 17, 2017 03:13 AM
ATX2000
Sep 28, 2016 01:42 PM
Jony0110
Nov 11, 2011 09:05 AM
rodgozinya
Feb 21, 2004 05:41 AM
