s2000 metallic sound from valvetrain?!
Old Dec 26, 2012 | 03:40 PM
lriver1004's Avatar
Default s2000 metallic sound from valvetrain?!
First off I have an ap1(00) with 75k and recently I started hearing a metallic rattle coming from my motor starting at about 3.5-4k to about vtec, it may rattle until redline but my car is so loud that i can't hear it beyond that. It also sounds like It's coming from the exhaust side. I think it's a cracked retainer or bent valve since I was going 80+ an. Shifted into second gear . The car idles fine and runs great still so I hope it isn't a bent valve. Amy input or ideas would be great, thanks.
Old Dec 26, 2012 | 03:45 PM
s2000maniac's Avatar
Make a video
Old Dec 26, 2012 | 04:02 PM
lriver1004's Avatar
I'll try to that soon but u might not be able to hear it from inside the car through the recording. It's really prominent from 4-5k rpm at 50% or more throttle
Old Dec 26, 2012 | 05:57 PM
johngamez's Avatar
I would get a compression test first. If any cylinder has low compression, do a leakdown test to find out if it's a bent valve (s). I would start here. Hope things turn out fine![:
Old Dec 26, 2012 | 06:15 PM
lriver1004's Avatar
Thanks I'll probably start here!
Old Dec 26, 2012 | 06:35 PM
johngamez's Avatar
Yeah, you should also check your retainers by looking at any sunken valve stems just to make sure you dont have any broken retainers.
Old Dec 26, 2012 | 06:48 PM
lriver1004's Avatar
Originally Posted by lriver1004' timestamp='1356578147' post='22231355
[quote name='johngamez' timestamp='1356577024' post='22231336']
[/quote]
Yeah I initially thought it was broken retainers since I did over-rev the s**t out of it
Old Dec 26, 2012 | 06:58 PM
Importedpower's Avatar
I found something like 11/16 of mine were cracked. A couple people made a big point of looking for bent valves. Well the shop that did the work toasted my motor so i got to take the old one apart. I didn't have a single bent valve with 11 cracked keepers. Takes a lot to bend these valves.
Old Dec 26, 2012 | 07:47 PM
johngamez's Avatar
keepers? I thought you would say retainers. How do you know it takes a lot to bend valves?
Old Dec 27, 2012 | 03:51 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Broken retainers make no noise at all.
