S2000 Steering Rack!
I know that if you use a rack and EPS from the same model year they will work. I don't know if you mix the EPS and rack from different years if they will work or not. That I never tried. Once installed you will need to reset the torque sensor neutral position
2000-2002 Steering ratio 13.8:1 lock-to-lock 2.4 wheel turns (Referance http://www.hondanews.com/channels/ho...ns?query=s2000)
2004-2009 Steering ratio 14.9:1 lock-to-lock 2.6 wheel turns, The EPS (Electrical Power Steering) system features an optimized steer response gain, while the software was updated to improve steering linearity and agility) http://www.hondanews.com/channels/ho...ns?query=s2000
2008-2009 CR Steering ratio 13.8:1 lock-to-lock 2.4 wheel turns http://www.hondanews.com/channels/ho...es?query=s2000
Originally Posted by iridedumped' timestamp='1394717510' post='23060697
After doing a quick Google search, I am lead to believe that the steering rack from 2000-2007 is all the same.
No problem to swap 00 to 05 rack, no need to relearn procedure if they have been installed before, eps module 00 to 05 was compatible, i have an 01 rack on my 05 and direct fit, never have to made a relearn!
AquilaEagle
Mar 28, 2015 11:56 AM
99SH
Feb 24, 2012 01:44 PM
s2kdriver80
Oct 25, 2003 01:10 PM
